Dipicting Screw Threads
Solid edge applies a graphic depiction of screw threads in draft mode that is typically not representative of the thread applied.  How do I scale thsi graphic to be a more representative view?
RE: Dipicting Screw Threads
db43,
What's wrong with the way screw threads are depicted in draft?
I can't see why you would need/want to scale anything.
bc
Solid edge allows modification of the thread image with the style command allowing a more realistic representation with options for left and right hand thread views.
Problem solved!
db43,
I'd  still be interested to know what exactly you have modified, and on what version.
bc
