SW06 slot creation
SW06 slot creation
A question for SW06 users ... In SW06 a 'rounded end' slot can be created using a single line in a 2D sketch. Does that feature also apply in a 3D sketch? eg. a radial slot in the wall of a tube or OD of a round bar.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
RE: SW06 slot creation
If anyone else knows, I am interested also.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
If it's not cilindrical or conical use this procedure:
Sketch the slot.
Curve>Split in one direction.
Surfce-Offset ( zero value) of the new splitted face.
Apply a Cut-thicken and you get any kind of slot whatsoever
Altough you can use a 3D-Sketch to generate a extrude you can't give a normal direction to its contour.
Daniel
Hope this helps.
Good one, Wrap work well!
It's not a 3DSketch, but will work for me.
Per CorBlimeyLimey's original question, I would like to figure out how to do it with a 3DSketch.
Chris
FAQ559-1100
FAQ559-716
