Corrosion inhibitors injection rate
Hi gangs,
can anyone help with calculation method for determining the rate of injecting corrotion inhibitor for a give flowrate through the pipeline.
best regards,
Buchi
Buchi
RE: Corrosion inhibitors injection rate
Certainly.
1) ask your corrosion inhibitor vendor what the recommended concentration in your application is
2) multiply the concentration with the given hydrocarbons flowrate
3) inject the inhibitor at the flowrate you just calculated
Does this help?
