View settings not responding (Toolkit?)
Hello group,
I have a problem. After an upgrade to a newer build of Unigraphics NX2 (for Windows) was recently installed the views in drafting mode appear as wire frame when running GM Toolkit regardless the view settings. When running UG by it self without GM Toolkit the view are operating correctly. The load options are set the same for both normal UG and Toolkit UG. Once the file as been saved in Toolkit UG with the wire frame views they stay wire frame when opened it in regular UG. Everything was running *fine* before this upgrade. I am at a lose as to how to remedy this one. Any help is appreciated!
Thanks in advance,
Craig
Canton, MI
Thanks in advance,
Craig
Canton, MI
RE: View settings not responding (Toolkit?)
http://www.eng-tips.com/viewthread.cfm?qid=104684
Thanks Eramo (Jason)!
Craig
