Excel Spreadsheet for Fluid Power Calcs
Does anyone uses a Excel Sheet for fluid power calcs on daily basis.
I was thinking to write one with unit conversion and basic pump/cylinder/motor calcs. I was just wondering if someone already has one, no point in reinventing the wheel :d
If anyone has one, would apprecaite if you can share it !
Guptara
RE: Excel Spreadsheet for Fluid Power Calcs
Guptara...
I have a simple home made spreadsheet into which you can put a cylinder bore, rod and stroke length. Input the pressure and oil flow and it will give the force, stroke speed, area, volume and power requirement @ 85% efficiency.
Tell me how to get it to you and you can have a copy.
Oh yeh...it's metric.
Hydromech
Hydraulic Systems Engineer
sen an adddress and I will send you a quite substantial Excell of basic formulas, motors, cylinder, condiuctors, heat, units etc.
kevincj46   at   hotmail.com
I just have to cross-check my result from a piping stress analysis program, and I need to do it fast. if some has excel sheets that proved great in stress analysis, please send as attachment to me a help with them.
f-fagbuyi@gaslink.org
Hello everybody:
hydromech and kcj, I am interested in this information and, if you do not have any inconvenience, may I have it?
catrachovasco@hotmail.com
Thanks a lot !
in your mailbox.
kcj
Thank you very much, kcj.
