Vacuum Thrust
Vacuum Thrust
Dear Expert,
A steam duct of Dia 2800mm is subjected to full vaccum. The duct starts from the turbine exhaust and goes to the air cooled condenser. From the turbine the duct drops for a height of 4M and takes a right angle turn, where it is supported to the ground.
We are connecting a simple axial bellow/Expansion joint after the turbine.
1.what is the amount of vacuum thrust tat wil be acting?
2.Where this will be acting?
3.The fondation should be designed for what load?
4. Will the vacuum load act on the joint of the turbine nozzle and bellow.
Your replies required urgently.
VRL3
VRL3
