Default working directory
How do you set the default working directory? Default such that it is the same directory every time ProE is started.
RE: Default working directory
You add that on your short cut
right click the ahort cut ...properties
start in
is where you place the directory name.ex; c:\proe\parts
in wildfire you also need the config option
file_open_default_folder   working_directory
