thermal heat conduction in an artery
Hello.
I need help regarding what should be a fairly simple calculation. I am applying heat (cautery) to the end of a length of arterial segment. I need to determine how far that heat transfers into the vessel. I also need to determine how it changes with changing vessel diameters but that should just be a function of the original equation. Any help would be greatly appreciated. Thanks,
