Summing by 24hr period - 7am to 7am
OK, I'll try and explain this 'logically':
My MS SQL application records outputs from a production line in real time. If I want to sum an output from a particular production line for a time period (say a month) and group by day, that works fine. The problem is that our 'Days' run from 7am to 7am and I need to sum that period and group by date of the start of our 'day'. I know I could add 0.278'ish to each day in the query, but then the query does not give the correct results between midnight and 7am.
What can I do?
RE: Summing by 24hr period - 7am to 7am
You could try subtracting 7/24 of a day from each timestamp - this would make 7 am be 12 am, and 6:59 am be 11:59 pm on the day before.  Then after you have the "day", add the time back to get the actual time.
Hope this helps!
