Active grain density calculation
I need a method of calculating/predicting the active grain density on the grinding wheel for predictive modelling work.
Any help would be gratefully received..
RE: Active grain density calculation
What kind of wheel are you loooking at?
I used Normal distribution for the grain heights for electroplated wheels. Measurements seemed to match well. I could calculate the active grain densiy from there depending on the wheel wear. The work is published in the 2004 ASME Journal of Mfg Sci. Let me know if you need any more info.
Good Luck,
Rama
