ACAD ADT 2006 SHEET SET
Has anyone found that if you have a sheet set, for say Mech, with 50 drawings, and you want to add another 50, its easier to delete current sheet set file and re-create a new one but with all dwg's (rather than import new dwgs as layout and muddling up all sheet numbers and order they plot etc).
This worked fine in 2005, but try it in 2006 and it 'can't see' the original drawings unless you painstakingly open up each one and remove previous sheet set association and re-save. I've tried various other ways, like removing all sheets first but nothing seems to work so if you know of a way i'd be most greatful to hear about it, but otherwise this can only be a bug in the not-so impressive 2006.
