Air compressors Inspection checklists
Does anybody have any template of inspection checklists for air screw compressors for maintenance phase (periodical inspection)?
Additional links to free templates are welcome.
Any help with this theme (periodical inspections checklists) is welcome.
Thanx
Thanx
RE: Air compressors Inspection checklists
1. Check E-stop for functionality. LO/TO here.
2. Blow radiator fins and coils free of debris.
3. Remove and inspect filter. Re-oil and replace, or install new, properly oiled filter.
4. Check unit oil. Drain completely if in excess of specified hours, and replace or top-off level in tank to specified level.
5. Bleed main compressed air tank free of pressure and moisture. Collect water sample for analysis, if desired.
6. Turn unit on, run for 20 minutes, monitor air temperature coming out of tank.
7. Check relief valves for operability.
8. Check pressure cut-off/cut-in switch against unit PSI gauge for correctness.
9. Visually check all fittings for observable pinhole leaks or looseness.
10. Record runtime hours, wipe down main control panel and gauge cluster, and return machine to normal operation.
