Tool to cut injector ports in a fuel rail?
I am trying to make a new custom set of fuel rails. I have been told that there is a special 'port tool' used to cut the injector holes in the bottom of the fuel rail, that makes the correct radius for the o-rings and such. Can you tell me what this is called and where I can find one please? These would be standard 24#, 36#, 42#, high/low imp., etc. type injectors like those made by Bosch and Lucas.
Any help would be appreciated.
L
L
RE: Tool to cut injector ports in a fuel rail?
I think the size was .546, but you need to verify that yourself, my tools havent been unpacked from the last move yet.
Do a good search, there are plenty to choose from.
Franz
Ninety percent of the injectors that are used in the aftermarket are designed for use with a 14.0mm (.551") bore for both injector inlet and outlet. No radius is needed in either bore, just a small 45 degree entry chamfer for ease of installation.
We use a modified 14mm end mill. This end mill has a drill ground on the end to reduce tool changes.
Will
