To open file format *.x_t in Catia
Hello there,
Is there anyway I can open a parasolid file format (*.x_t or a *.mod) file in Catia? I am using Catia V5R14.
Thanks in Advance
Sandy
RE: To open file format *.x_t in Catia
If you have access to the correct multi-CAx plug-in, Catia V5 should be able to open a parasolid into a CATProduct.  I checked the following link and ParaSolid is mentioned as having a valid Multi-CAx product.
http://www-306.ibm.com/software/applications/plm/catiav5/prods/idl/
Good luck
"Pinky, are you thinking what I'm thinking?"
"Yes, Brain, but isn't that dangerous?"
I have the correct multi-CAx pulg-in. I am able to open all the *.iges, *.stp, *.stl..etc...except for the *.x_t format files. Is there any converters that I can use to convert it to some other format that is readable in Catia?
I had the same problem.
I wrote an own "parasolid in" bequase Dassau
was not intressted to fix it
SL
How are you trying to read it?  File Open? Try creating a Product and using Insert Existing Object, then select it.
I tried creating a product and tried inserting an existing object in *.x_t file format. But it gave me an error saying "Insert failed due to invalid and inconsistent extension type"
Is there a solution for this??
