Browsing Intralink
Browsing Intralink
Hello.
I would like to browse my drawings contained within the common space directory before opening, but unfortunately when I click on each drawing no preview is
available, so I end up opening drawings just to see the contents. I have my config.pro set to Save_drawing_picture_file embed
I have Wildfire open and I am selecting the common space icon in the left column of the pro section. I hope that is clear.
Any help
greatly appreciated.
Any help
RE: Browsing Intralink
Your drawings have to be save with that option set, then you can preview them. To prove this save a drawing new or one already in common space, check it into common space, then you can preview it.
Tofflemire
Are right clicking on the drawing in common space, to see menu options to pop up, then there is an infomation button, this should give you thumbnail preview, then you can enlarge that thumbnail.
Tofflemire
By the way I posted this question in 3 different forums and you are the only one who answered.
Thank you very much
Frank
You can do the same for the parts and assemblies. Only generic will show up, not family table instances. You can spin these also, wireframe and solid.
Tofflemire
Thanks again
