Will this work?
Will this work?
Will this work?
HI,
can someone tell me if this will work because I am a bit inexperienced in this field:
Having a boiler constantly fed with water and the steam that is produced stored in a cylinder or little tank. the steam can then be let out at a controlled pace or stopped for other use..
thnx for ur time
RE: Will this work?
emZee18,
   The volume of constantly fed water could be steam volume of 100 X the liquid.
The cylinder or little tank will be limiting factor.
RE: Will this work?
Thanks for the link, i have an idea for an engine and the info has helped a lot on details, now all i need is someone to show the idea to, it is something that has a huge chance of not working but i need expert advice.
