Creating Threadmill cut on a surface
I am using a 40 threads/inch threadmill to cut a revolved groove on a flat surface. Can anybody provide a simple way to make the cut without sketching all 40 grooves.
RE: Creating Threadmill cut on a surface
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
If the grooves are decreasing in diameter, you can use the Linear Sketch Step and Repeat function when creating the sketch.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
when I pattern one groove the diameters overlap creating a "8" shape instead of concentric grooves. Looking at the cross section, it would look like 20 thread pitches running radially along the surface. Basically like what coreBlimeylimey mentioned as decreasing in diameter.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Thanks CoreyBlimeylimey.
