looking for atmosphere pressure plasma generator
I need a high frequency pulse output plasma generator(10~50kHz)?may be couple with a high voltage transformer is better.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: looking for atmosphere pressure plasma generator
You need to be more specific.. 1W or 100kW? Three phase?
Duty cycle of pulses? May be couple with transformer??
Water cooled? Open loop? Closed loop? Directional coupler?
Your question is sooo vague, it makes me wonder if you understand the first thing about plasma generators.
Generator?
power?1kW
Output voltage MAX.:1kV
out put frequency range?10 ~ 20 kHz
Mains voltage, standard 100~11OV
Transformer?
performance:1KVA
raise generator's output voltage up to 40kv
stady voltage: 20kv?10~20Hz?
