Random cosmetic thread show/hide generator
Hi everyone,
Has anyone managed to find a way to disable this 'feature' in drawings.
By this I mean set things up so thread annotations don't show up on the non-visible surfaces of drawing wiews. It's a real drag going through every drawing and hiding the ones that do happen to show up that shouldn't have.
Cheers in advance.
Cheers in advance.
RE: Random cosmetic thread show/hide generator
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
Apparantly this has been a problem for years and people (my colleagues) just put up with it and hide thread annotations that shouldn't be showing. I can't accept that as being good enough.
I didn't mean there actually was a deliberate function to do this.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
If you do your Hole Wizard and put a few holes in. Then decide later to add more holes by just editing the sketch and adding points...you won't get a Cosmetic Thread until you select the Feaure and do an Edit Feature and click OK to each of the dialog boxes.
Ken
