Note Callouts and Flags
Is there a standard that specifies whether note references should have a triangle or square around them?
RE: Note Callouts and Flags
Different companies use different "flags". The company I'm currently with prefers the upright ('point' upward) equilateral triangle. Some rotate that same triangle 90 deg CW ('point' to the right), others use a hex or a five sided flag (somewhat pennant shaped).
The square can be confused with other symbols or notations such as note outlines (which some companies use), basic dimensions (esp. on metric drawings) or even the square symbol that preceeds a dimension (sometimes used in GD&T).
TTFN
John
