Array comparisons
Array comparisons
Array comparisons
I am new at arrays in Mathcad. How can you compare the corresponding values in 2 arrays and write the maximum of the 2 to a new array?
For instance I have an array called "a" which has 1 column and 3 rows. I want to compare each value to the same position in "b" and write the maximum for each position to a new array called "c".
When I use c=max(a,b) it just returns one value for "c" instead of a new array.
RE: Array comparisons
Do it for each element ....
i:= 1..rows(a)
c:=max(a[i,b[i)
Rick D.
Type c:max(a,b) select the entire max(a,b) expression and type <ctrl><minus>, which will vectorize the function and perform it for each element in each vector.
Also, the above posting should say c[i:max(a[i,b[i) if you want to go that route.
TTFN
I was looking for something like that long time ago, now i make what rd78 and IRstuff said and nothing happends, i tried to <ctrl> <minus> and the arrow won't stay on of the (a,b), look:
Try initializing c in your final attempt, which otherwise looks fine to me. ie insert c[i:0 just below i:1;rows(a)
Sorry, i don't know if that will work, it just seems likely.
Cheers
Greg Locock
Default array indices in Mathcad start at 0.  Therefore, the range variable i should be defined as i:0;rows(a)-1.
The error message relates to trying to access a[3 and b[3, which don't exist.
TTFN
Thanks to --> IRstuff
It worked!! look,.....
