Reading data in an external file
Hi everyone.
I am trying to read data from an external file into my ABAQUS input file.  i have read up on the *INCLUDE, INPUT= option and understand its function.  However, my problem is this:  I have a DSLOAD, and the input file is as follows:
*DSLOAD
__PICKEDSURF33, EDNOR, 0.175
Now, instead of 0.175 as my load magnitude, I want to read a value in form an external file.  How would I do that??
Ive tried reading in the whole second line, ie have the following:
*DSLOAD
*INCLUDE, INPUT=file
where file (which I can create each time changing the load magnitude as needed) contains   __PICKEDSURF33, EDNOR, 0.175  but then i get an error saying the DSLOAD option needs a surface name.
Thank for your help,
Andrea
RE: Reading data in an external file
Andrea - have you tried including the whole *DSLOAD card within the file you are *INPUTing?
CODE
model data
*INPUT,file=test.dat
CODE
test.dat
*DSLOAD
Otherwise, try your first option above but make sure there are no spaces above the __PICKEDSURF33, EDNOR, 0.175 (the spaces will be used by ABAQUS and treated as zero entry).
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
Hi Drej, thanks for your answer.
Are you sure about the *INPUT line?? It is not an ABAQUS keyword.  I have had no success in solving my problem.  I have tried reading form an external file in the *NODE line,
by having *NODE, INPUT=nodes and having my node definition in the file named "nodes" and everything works.  I have had no success as far tas the DSLOAD line goes, and also i tried specifying the layup of a composite solid shell section from and external files and i get an input file error when trying to raed this too.  any ideas??
Andrea
It should be *INCLUDE not *INPUT (am mixing my ANSYS/ABAQUS command: /INPUT=ANSYS, *INCLUDE=ABAQUS).
CODE
*INCLUDE, INPUT=test.dat
test.dat
CODE
*DSLOAD
Thanks for that but it only works partially.  Its strange cos using the *INCLUDE, FILE= line works when I put the composite stacking sequence definition in an external file and then read it in after the shell section definition.  However for the DSLOAD option it doesnt work (just says that I need a surface name, even though its there).
Thanks again,
Andrea
Hi andrearrd,
I dont know whether this would help you or not cause I am just a begineer in Abaqus.
When I had to give different loads in CLOAD option I used amplitude function. Ofcourse amp is related to time but I think you can call a input file in another input file.
let me tell u wat i did,
*INCLUDE, INPUT=CLOADF
then again
CLOADF contains funtions calling amplitude fn.
Like
*INCLUDE, INPUT=AMP1
etc.
There  by I have defined different load values for different times.
Hope this helps and sorry if I had confused u,
Maddy.
