Weldments and Assemblys
I built a master template of a skid we use quite often into the weldment enviroment. Then in the assembly enviroment I added all the other parts that go along with it.
I would like to BOM the entire assemby in one BOM. I want all the cut list items to show up in the BOM fuction of the assembly drawing. Is there a way to do this without cleaving any links. I basically want one big BOM of everything. The reason for this is the weldment feature only allows one material and have 6 or 7. Also we have several small assemblies that we have dumped together. I didn't like my VAR's answer to this problem that is why I am here to ask the pros.
Thanks, and I hope I made myself clear.
RE: Weldments and Assemblys
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.1
So the above is the way it seems to work.
I hope that makes sense?
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
