VOC Evaporation
VOC Evaporation
I am trying to determine the approach to take to calculate the volume of air required to aerate hydrocarbon contaminated soil so as to transfer the hydrocarbons into the airstream (ambient conditions). This will be done ex-situ in an enclosed environment. The process will be continuous, not batch. The concentration of hydrocarbons (C2 to C20)are known in terms of ppm. Secondly, because the vapour/air stream will be contained consideration must be made for LEL and UEL. Any thoughts on how to proceed?
RE: VOC Evaporation
After doing the tests you could test each batch of soil for hydrocarbons to see the extent of reduction in hydrocarbon concentration. This should give at least a ballpark figure of aeration required.
ANother attack might be to call a vendor of this service (soil vapor extraction). They may have spreadsheets that can be plugged in to crank out the answers.
RE: VOC Evaporation
RE: VOC Evaporation
RE: VOC Evaporation
