Ammonia Refrigeration Plant Risk Management Plan
I am developing an RMP (risk management plan as required by the U.S. EPA) for a client with an ammonia refrigeration plant of 250 tons per day refrigeration capacity. I need help in deciding whether or not the plant correctly handles their relief valve vents and their emergency release dump lines. Can any of you, involved with an ammonia refrigeration plant in the U.S of about the same size, help me with these questions:
(a) How does your plant handle and/or route relief valve vents and emergency dump lines?
(b) If your relief vents and emergency dump lines are routed into a water storage vessel, does it contain enough water to absorb 100 percent of your plant's ammonia inventory?
(c) Is there some standard or code that governs how much water should be in such a water storage vessel?
Thanks for any guidance you can give me.
Milton Beychok
mbeychok@home.com
Air Pollution Dispersion Modeling
Visit my URL to learn about "Fundamentals of Stack Gas Dispersion",
the most comprehensive book on air dispersion modeling of
continuous, buoyant air pollution plumes. Site includes published
peer reviews and complete Table of Contents.
RE: Ammonia Refrigeration Plant Risk Management Plan
Thanks for your response and I will await any further information you may make available. I really appreciate your help.
Milton Beychok
mbeychok@home.com
Visit my website to learn about "Fundamentals of Stack Gas Dispersion", the most comprehensive book on air dispersion modeling of continuous, buoyant air pollution plumes. The site includes published peer reviews and the complete Table of Contents.
Out pressure relief system consists of dual pressure relief valves. This is a passive safety system which was designed by code to absorb then ammonia, preventing the ammonia from entering the building atmosphere. pH in the tanks is monitored and fresh water is added whith an increase in pH. Over flow drains are piped to sanitary sewer which is also monitored. Our systems are designed to meet the Uniform fire codes, County toxic gas ordinance and IIAR standards.
The tanks should be sized so that any release and in crease of pH can be controlled to acceptible levels. Here are a few sites that might be of interest to you.
http://www.nh3tech.org/n3.html
http://www.epa.gov/ceppo/
