120 Hz vibration peak
I am doing vibration analysis on some of the fans our company produces. I am finding a large contributor occurs at 7200 cpm or 120Hz. The motors are less than 1hp, single phase, 60Hz, 115V induction motors. Could someone explain this peak at 120 Hz? I know it's a 2nd harmonic of 60Hz, but that's about it.
RE: 120 Hz vibration peak
Most common in 2-pole motors (3600 rpm or 3000 rpm).
Biggest thing to look at is the motor feet. If they cause distortion of the motor casing than 2*LF can occur.
Thinking about small motors, if the driven component is putting a bend on the shaft that can cause 2*LF.
Operating a motor at higher votlage or lower frequency than intended can increase 2*LF vibration.
