condensation issue at the grilles for gymnasium
I have an issue with condensation on exposed supply grilles. This new rooftop d/x with VFD in a new gymnasium is experiencing condensation on supply grilles and exposed ductwork. The building is under construction. The unit need to cool the sapce and remove the humidity so the floors can be installed. The unit is sized for many people while they are playing. The unit may be cycling off too quickly. How can we utilize the VFD to possibly lower the CFM volume and increase the time before the space thermostat cycle off the d/x. What is the main cause and remedies for this system.
RE: condensation issue at the grilles for gymnasium
HVAC68
