backups?
backups?
backups?
I keep getting these files when I save a workbook.  I think there some kind of back up.  Are they?  How do I stop them from being created?
[URL=http://img20.imageshack.us/my.php?image=untitled7pt.jpg][IMG]http://img20.imageshack.us/img20/5013/untitled7pt.th.jpg[/IMG][/URL]
Properties
[url=http://img20.imageshack.us/my.php?image=properties4bz.jpg][img=http://img20.imageshack.us/img20/6352/properties4bz.th.jpg][/url]
Grant
Applications Engineer
SW2005 SP 3.1
IBM InteliStation Pro M
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1100
RE: backups?
Possibly.  You need to see if there are any extensions on the files by changing your Explorer display to "Details."
However, it's unlikely to be a backup file from Excel, since backup files usually contain the name of the source file.
TTFN
RE: backups?
IRstuff,
There are no file extensions.  For type it just says file.  Thats whats getting me.  I have no idea what they are.  When I double click on them they open excel and have my last saved excel data.  That's why I thought it might be a back up but like you said excel back ups are different.
Grant
SW2005 SP 3.1
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
RE: backups?
It could be a backup file from before the backup process is complete. (i.e. Ultimately it'll be called filename.tmp, but while it's still saving the backup it's called 0005621 with or without an extension.)
Check your autosave settings.
Does the file disappear when you close the spreadsheet? Is it a shared spreadsheet?
RE: backups?
I don't have the autosave add-in added so it's probably not a autosave issue.  As far as I know.
No the file never goes away.  They're created every time I save the spreadsheet and stay in the folder where the spreadsheet was saved.  So if I save 5 times I get 5 of these "unknown" files.  It's getting kind of annoying deleting these files every few hours.
I don't know what a shared spreadsheet is.
Grant
SW2005 SP 3.1
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
RE: backups?
Okay, but these files get deleted when you finally close the file, right? So they're interim files, one for every time you save -- which allow you go to back to a previously saved version if you need to?
Does this happen for every single Excel file you use, or just this one? What version of Office/Excel are you using?
When you click File --> Save As there should be an "options" tab somewhere (it'll be on the top right in Office 2003) - check if you have something screwy in there.
RE: backups?
No they don't get deleted when the file closes.  They remain as is like in the pictures posted above.
It only happens with this spreadsheet.  Office/excel 2000.
"When you click File --> Save As there should be an "options" tab somewhere (it'll be on the top right in Office 2003) - check if you have something screwy in there."
The only options I see are general options ie. autosave, read only etc.. under --> tools and they seem correct.
Should I send something to microsoft?
Grant
SW2005 SP 3.1
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
RE: backups?
See if you can open them in Excel.
TTFN
RE: backups?
Under the Save --> Tools --> General Options tab, does it have an option for "Always create backups"?
You could submit a bug report to Microsoft if you want to, but given that it only occurs with this workbook, it might not be a bug. Or it might be a bug in that the temporary file is not erased when the save process is complete.
Are your Office service packs/updates up-to-date? How about your Windows updates (I see you're proudly proclaiming SP2). When last did you restart your computer?
Have you tried to Save As under a different name and checking if you get the same bug? How about saving as an old version and then saving back to the current version again.
As a last resort, you could open a new workbook and then copy and paste sheet to sheet from the old workbook to the new one.
RE: backups?
FYI
I have all of my PC/windows specs listed for the SolidWorks forum.
Everything is upto date. This problem has been going on for awhile (weeks).  "Save as" does the same thing.
I copied all sheets into a new work book this seemed to have gotten rid of the problem for now!!  So thanks for your help.
Grant
SW2005 SP 3.1
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
RE: backups?
That doesn't sound right - you have to have the file type associated with excel for the double-click part to work, as far as I know.  Even if the file type .(blank) is associated with excel, how does excel know what to do with it when it opens it?  Try doing a directory listing from a command window, and see if you get the same results for the file extension.
Also, from the file that had the problem, open up the visual basic editor, go to the project explorer, and look for any VB scripts.  The behavior is certainly puzzling, and it would make me suspicious until I got it sorted out if my machine were doing that.
RE: backups?
There is VBA code/macros.  When I reinserted the VBA code after my above post the problem came back.  I beleive now it has something to do with the VBA.
Grant
SW2005 SP 3.1
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
RE: backups?
Look for something in the VBA code that is trying to save your file, or else try to add some code to produce an error log.
RE: backups?
or just post it for us to have a look at (more fun that way)
RE: backups?
The spreadsheet gets saved by the macro after it is done running.
The VBA has lots of code (when were done it'll build a complete conveyor in SolidWorks).Should I just post the part where the spreedsheet gets saved?  How should I do it. Just post a pic?
Grant
SW2005 SP 3.1
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
RE: backups?
Copy and paste the code wrapped in [code] [/code] tags. If you're feeling froggy you can color code the commands and comments, but if we paste it into VBEditor, it'll color code it for us.
I'd lay money on there being an error in the Save code.  You can try error trapping it with the following code.
CODE
On Error Goto ErrorCode
(save code statements)
On Error Resume Next
(scroll to the end of the code)
Exit Sub'this makes sure you ignore the error handling code if no error occurred
ErrorCode: Msgbox "oh poo"
End Sub
RE: backups?
I'll give you all the module code (it's alot).  There's code for forms but from what i'm getting you only need the module and save code.
FYI I didn't write the code.  I'm a newbie with VBA.
Have at guys!!!
thanks if you find my problem.
CODE
Option Explicit
Dim CurrentDoc As String
Dim LastDoc As String
Dim UpdateArray() As String
Dim DocType As Long
Dim UpdateRetVal As Boolean
Dim SaveState As Boolean
Dim swModel As SldWorks.ModelDoc2
Dim xl As Excel.Application
Dim xlDesTable As Excel.Worksheet
Dim Continue As Integer
Dim Activecolumns As Integer
Dim ColumnCounter As Integer
Dim RowCounter As Integer
Public Parts As Integer
Public Data As Integer
Public ConveyorType As Integer
Dim xlname As String
Public Sub UpdatePart()
    'Declarations
    Dim swApp As SldWorks.SldWorks
    Dim swDesTable As SldWorks.DesignTable
    Dim nTotalRow As Long
    Dim flError As Long
    Dim flWarning As Long
    Dim SaveError As Long
    Dim SaveWarning As Long
    Dim TestCount As Long
    Dim Result As Integer
    Dim MbResult As Integer
    Dim RegenCounter As Integer
    Dim ReadState As Boolean
    Dim NewConfig As Boolean
    Dim Test As Boolean
    'Test Assignments
    ColumnCounter = 0
    'Set SaveState to False
    SaveState = False
    RegenCounter = 0
ReloadFile:
    'Call Application
    Set swApp = CreateObject("sldworks.application")
    'Make Solidworks Visiable
    swApp.Visible = True
    'Check for New Update Document
    If LastDoc <> CurrentDoc Then
        'Check for LastDoc
        If LastDoc <> "None" Then
            'Close the Last Document Updated
            swApp.CloseDoc LastDoc
        End If
        'Open Model to Update
        Set swModel = swApp.OpenDoc6(CurrentDoc, _
                            DocType, _
                            swOpenDocOptions_Silent, _
                            "Default", _
                            flError, _
                            flWarning)
    End If
    'Check for File Errors
    Select Case flError
        'No Errors
        Case 0
        'File not found error
        Case 2
            'Activate Excel Window
            AppActivate "Microsoft Excel"
            'Warn user of error
            MsgBox "An error as occured while" + vbCrLf + _
                "opening the file" + vbCrLf + vbCrLf + Chr(&H22) + _
                CurrentDoc + Chr(&H22) + vbCrLf + vbCrLf + _
                "Please verify that the file exists in" + vbCrLf + _
                "in the above location and that the" + vbCrLf + _
                "name matches what is shown above." + vbCrLf + _
                vbCrLf + "If the file has been moved or renamed" + _
                vbCrLf + "on purpose, please update the Part #'s" + _
                vbCrLf + "sheet of this file with the new name" + _
                vbCrLf + "and location." + vbCrLf + vbCrLf + _
                "Exiting update", vbExclamation Or vbOKOnly, _
                "File Error"
            'Set continue to exit the configuratior
            Continue = 0
            'Exit the program
            Exit Sub
        'File already open
        Case 65536
            'Warn user of File Error
            MbResult = MsgBox("The file " + Chr(&H22) + CurrentDoc + Chr(&H22) + _
                vbCrLf + "is already open in SolidWorks. Please close" + _
                vbCrLf + "any documents that are referencing this" + _
                vbCrLf + "file and click Retry to continue this update." + _
                vbCrLf + vbCrLf + "Clicking cancel will exit this update", _
                vbExclamation Or vbRetryCancel, "File Error")
            'Check for Message Box response
            If MbResult = 4 Then
                'Try to reload the file without Errors
                GoTo ReloadFile
            Else
                'Warn user about exit
                MsgBox "Exiting Update", vbOKOnly, "Message"
                'Set continue to exit the configurator
                Continue = 0
                'Exit the program
                Exit Sub
            End If
        'Other Errors
        Case Else
            'Warn user of file error
            MsgBox "An error has occured while" + vbCrLf + _
                "opening the file " + vbCrLf + vbCrLf + Chr(&H22) + _
                "For information about this error, please" + vbCrLf + _
                "contact John Zelli at Ext. 4805 with the" + vbCrLf + _
                "Error Number and File Name" + vbCrLf + vbCrLf + _
                "Error Number : " + CStr(flError) + vbCrLf + vbCrLf + _
                "Exiting Update", vbExclamation Or vbOKOnly, "File Error"
            'Set Continue to exit configurator
            Continue = 0
            'Exit the Program
            Exit Sub
    End Select
    'Check for File Warnings
    Select Case flWarning
        'No warnings
        Case 0
        'File Opens Read Only
        Case 2
            'Get Write Access
            ReadState = swModel.SetReadOnlyState(False)
            'Confirm write access granted
            If ReadState = 0 Then
                'Warn user of error
                MsgBox "Update cannot continue." + vbCrLf + _
                    "Write Access for the file" + vbCrLf + vbCrLf + _
                    Chr(&H22) + CurrentDoc + Chr(&H22) + vbCrLf + vbCrLf + _
                    "could not be obtained." + vbCrLf + _
                    "Please verify you have Write Access to" + _
                    vbCrLf + "this location and run the update again." + _
                    vbCrLf + vbCrLf + "Exiting Update!", vbExclamation Or vbOKOnly, _
                    "File Error"
                Continue = 0
                'Exit the Program
                Exit Sub
            End If
        'Sharing Error
        Case 4
            'Activate Excel
            'Warn user another person has the file open for write access
            MbResult = MsgBox("A sharing error has been detected while opening the file" + _
                vbCrLf + vbCrLf + Chr(&H22) + CurrentDoc + Chr(&H22) + vbCrLf + _
                vbCrLf + "WITH THIS WARNING BOX OPEN" + vbCrLf + vbCrLf + _
                "Activate the SolidWorks Window" + vbCrLf + "Select File, Reload" + _
                vbCrLf + vbCrLf + "In the reload dialog box, find the file in error," + _
                vbCrLf + "and get the name of the user with write access." + vbCrLf + vbCrLf + _
                "Next contact the user and have them save the file" + vbCrLf + _
                "and return the file to Read-Only status." + vbCrLf + _
                "(Select File, Make Read Only)." + vbCrLf + vbCrLf + _
                "After file has changed to Read-Only, " + vbCrLf + _
                "Click Cancel in the Reload dialog box," + vbCrLf + _
                "and Retry in this warning box to" + vbCrLf + _
                "continue the update" + vbCrLf + vbCrLf + _
                "Clicking Cancel will exit the update.", vbExclamation Or vbRetryCancel, _
                "File Sharing Error")
            'Check user input
                'Close the current doc
                swApp.CloseDoc CurrentDoc
                'Reopen the file and continue the update
                GoTo ReloadFile
            Else
                Continue = 0
                'Exit the Program
                Exit Sub
            End If
        'Needs Regen
        Case 32
            'Increment Counter
            RegenCounter = RegenCounter + 1
            'Check counter status
            If RegenCounter = 1 Then
                'Regenerate File
                swModel.Rebuild swRebuildAll
            Else
                'Send Message to user
                MsgBox "The File" + vbCrLf + vbCrLf + Chr(&H22) + _
                    CurrentDoc + Chr(&H22) + "Could not be Rebuilt" _
                    + vbCrLf + vbCrLf + "Please Rebuild manually and resave" + vbCrLf _
                    + vbCrLf + "Exiting Update", vbExclamation Or vbOKOnly, "Rebuild Error"
            End If
            'Save Document
            swModel.Save3 swSaveAsOptions_Silent, SaveError, SaveWarning
                GoTo ReloadFile
        'File Aready Open
        Case 128
                GoTo ReloadFile
            Else
                Continue = 0
                'Exit the program
                Exit Sub
            End If
        'Other Errors
        Case Else
                "Warning Number and File Name" + vbCrLf + vbCrLf + _
                "Warning Number : " + CStr(flWarning) + vbCrLf + vbCrLf + _
            Continue = 0
            'Exit the Program
            Exit Sub
    End Select
    'Aquire Model Design Table
    Set swDesTable = swModel.GetDesignTable
    'Open Table for edit
    swDesTable.EditTable
    'Activate Excel for Design Table Update
    Set xl = GetObject(, "excel.application")
    'Get # of Rows
    nTotalRow = swDesTable.GetTotalRowCount + 1
    'Access Design Table In Excel
    Set xlDesTable = xl.ActiveWorkbook.Worksheets(1)
    'Get WorkBook Name
    xlname = xl.ActiveWorkbook.Name
    'Confirm the design table is selected for the update
    If xlname <> "L Conveyor Configurator.xls" Then
        'Paste Match formula into design table
        xl.ActiveSheet.Cells(1, 6).Formula = "=ISNUMBER(MATCH(" & Chr(&H22) & _
            UpdateArray(0) & Chr(&H22) & ",A3:A" & nTotalRow + 1 & ",0))"
        If xl.ActiveSheet.Cells(1, 6).Value = 0 Then
            'Clear Cell F1
            xl.ActiveSheet.Cells(1, 6).Clear
        Else
             nTotalRow = xl.WorksheetFunction.Match(UpdateArray(0), _
                Range(Cells(3, 1), Cells(nTotalRow + 1, 1)), 0)
            'Clear cell F1
        End If
        'Add New Configuration
        Do While ColumnCounter <= Activecolumns
            'Add Individual Values to Design Table
            xlDesTable.Cells(nTotalRow + 2, ColumnCounter + 1).Value = _
                UpdateArray(ColumnCounter)
            'Incriment Column Counter
            ColumnCounter = ColumnCounter + 1
        Loop
        'Set update to continue to next part
        Continue = 1
    Else
        'Warn User of file error
        MsgBox "Cannot Update Part!" + vbCrLf + _
            "The Design Table Did Not Open Correctly" + vbCrLf + vbCrLf + _
            "Exiting Update", vbExclamation Or vbOKOnly, _
            "File Error"
        Continue = 0
        'Exit the Program
        Exit Sub
    End If
    'Set row changed
    swDesTable.SetRowChanged nTotalRow
    'Update the Design Table
    UpdateRetVal = swDesTable.UpdateTable(swUpdateDesignTableSelected, True)
    'Confirm table update
    If UpdateRetVal = 1 Then
        'Save Document
        SaveState = swModel.Save3(swSaveAsOptions_Silent, SaveError, SaveWarning)
    End If
End Sub
Sub UpdateAssembly()
    'Declarations
    Dim NFApp As SldWorks.SldWorks
    Dim NFModel As SldWorks.ModelDoc2
    Dim NFDesTable As SldWorks.DesignTable
    Dim NFSave As Boolean
    Dim NFUpdate As Boolean
    Dim ActiveRows As Integer
    Dim UpdateColumn As Integer
    Dim UpdateRow As Integer
    Dim FNrow As Integer
    Dim FileName As String
    Dim Extension As String
    Dim NFName As String
    Dim flError As Long
    Dim NFErrors As Long
    Dim NFWarnings As Long
    'Info so control U will update last Conveyor type
    Data = Worksheets("Main").Cells(1, 2).Value
    Parts = Worksheets("Main").Cells(2, 2).Value
    'Close open solidworks docs warning
    MsgBox "For better results please save and" + _
        vbCrLf + "close all open SolidWorks Documents." + _
        vbCrLf + vbCrLf + "Click OK to Continue", _
        vbInformation Or vbOKOnly, "Message"
    'Set LastDoc to None
    LastDoc = "None"
    'Set Row Counter for First Data Row
    RowCounter = 2
    'Activate Part #'s Worksheet
    Worksheets(Parts).Activate
    'Count # of rows for Update
    ActiveRows = Application.WorksheetFunction _
        .CountA(Worksheets(Parts).Range("A:A"))
    Do While RowCounter <= ActiveRows + 1
        'Check if Configuration Exists
        If Worksheets(Parts).Cells(RowCounter, 3) = False Then
RestartExtensionCheck:
            'Get File Path and Name to Update
            CurrentDoc = Worksheets(Parts).Cells(RowCounter, 6) + _
                Worksheets(Parts).Cells(RowCounter, 4)
            'Get File Name
            FileName = Worksheets(Parts).Cells(RowCounter, 4)
            'Get File Extension
            Extension = Right(FileName, Len(FileName) - InStrRev(FileName, "."))
            'Assign DocType Based on Extension
            Select Case Extension
                Case "SLDPRT"
                    DocType = swDocPART
                Case "SLDASM"
                    DocType = swDocASSEMBLY
                Case "SLDDRW"
                    DocType = swDocDRAWING
                Case Else
                    'Show File Extension Userform
                    FileExtension.Show vbModal
                    'Rerun the File Extension Check
                    GoTo RestartExtensionCheck
            End Select
            'Get # of Parameters for File Update
            Activecolumns = Application.WorksheetFunction _
                .CountA(Worksheets(Parts).Rows(RowCounter)) - 7
            'Rediminsion the Dynamic Array
            ReDim UpdateArray(Activecolumns)
            'Zero ColumnCounter
            ColumnCounter = 0
            'Add Config Name to UpdateArray
            UpdateArray(ColumnCounter) = Cells(RowCounter, ColumnCounter + 2)
            'Incriment ColumnCounter
            'Assign Information to UpdateArray
                'Assign Individual Values to UpdateArray
                UpdateArray(ColumnCounter) = Worksheets(Parts). _
                    Cells(RowCounter, ColumnCounter + 7).Value
            Loop
            'Call Update Part Function
            Call UpdatePart
            'Check Continue Status
            If Continue = 0 Then
                'Stop the Update and Save the Excel File
                GoTo SaveExcelFile
            End If
            'Examine Save Document Return Value
            If SaveState = 1 Then
                'Activate Configurations Worksheet
                Worksheets(Worksheets("Main").Cells(3, 2).Value).Activate
                'Set Update Column
                UpdateColumn = Worksheets(Parts).Cells(RowCounter, 7)
                'Select Update Column
                Worksheets(Worksheets("Main").Cells(3, 2).Value).Cells(1, UpdateColumn).Select
                'Get Active Configuration Count
                UpdateRow = Application.WorksheetFunction _
                    .CountA(Worksheets(Worksheets("Main").Cells(3, 2).Value).Columns(UpdateColumn)) + 1
                'Add New Configuration To List
                Worksheets(Worksheets("Main").Cells(3, 2).Value).Cells(UpdateRow, UpdateColumn).Value = UpdateArray(0)
                'Update Last Doc to Current Doc
                LastDoc = CurrentDoc
            End If
        End If
        'Incriment Row Counter
        RowCounter = RowCounter + 1
    Loop
    'Looking for file name row
    FNrow = Application.WorksheetFunction.Match("Filename", Worksheets(Data).Range("A:A"), 0)
    'Get project file name
    NFName = "W:\Macro Project Folder\" + Worksheets(Data).Cells(FNrow, 2) + _
                    ".SLDASM"
    'Get number of new File update arguments
    Activecolumns = Worksheets(Data).Cells(FNrow + 1, 2).Value
    'Redimension the UpdateArray
    ReDim UpdateArray(Activecolumns - 1)
    'Zero Column Counter
    ColumnCounter = 0
    'Get update arguments
    Do While ColumnCounter < Activecolumns
        'Assign individual update values
        UpdateArray(ColumnCounter) = Worksheets(Data).Cells(FNrow + 2, ColumnCounter + 1).Value
        'Incriment counter
    Loop
    'Open Solidworks
    Set NFApp = CreateObject("sldworks.application")
    'Make Solidworks visible
    NFApp.Visible = True
    'Close Last Updated Part
    NFApp.CloseDoc CurrentDoc
    'Open Generic Assembly
    Set NFModel = NFApp.OpenDoc6("W:\Macro Project Folder\Generic Assembly.SLDASM", _
                            swDocASSEMBLY, _
                            "", _
                            flError, _
                            flWarning)
    'Save Generic Conveyor as Project Conveyor
    NFSave = NFModel.SaveAs4(NFName, _
                        swSaveAsCurrentVersion, _
                        swSaveAsOptions_Silent, _
                        NFErrors, _
                        NFWarnings)
    'Check nem file saved
    If NFSave = 1 Then
        'Get the New File Design Table
        Set NFDesTable = NFModel.GetDesignTable
        'Open table for edit
        NFDesTable.EditTable
        'Access Design Table in Excel
        'Get Workbook Name
        'Confirm the design table is selected for update
            'Reset Column Counter
            ColumnCounter = 0
            'Update Default Configuration to Project Configuration
                'Add individual Values to Design Table
                xlDesTable.Cells(3, ColumnCounter + 2).Value = _
            Loop
            'Set continue to give user compleated macro message
            Continue = 1
        Else
            MsgBox "Cannot update the final assembly!" + vbCrLf + _
                "The design table did not open correctly" + vbCrLf + _
                vbCrLf + "Exiting Update", vbExclamation Or vbOKOnly, _
                "Design Table Error"
            'Set continue to exit the update
            Continue = 0
        End If
        'Update and close the design table
        NFUpdate = NFDesTable.UpdateTable(swUpdateDesignTableAll, True)
        'Check for sucessful table update
        If NFUpdate = 1 Then
            'Save document
            NFSave = NFModel.Save3(swSaveAsOptions_Silent, NFErrors, NFWarnings)
        End If
    End If
SaveExcelFile:
    'Save Excel File
    Workbooks("L Conveyor Configurator.xls").Save
    'Check to see that the workbook saved
    If Workbooks("L Conveyor Configurator.xls").Saved Then
        'Check to see the update compleated
        If Continue = 1 Then
            'Tell user Configuration is Created
            MsgBox "The Assembly has been Created as" + _
                vbCrLf + "Configuration " + Chr(&H22) + _
                Worksheets(Parts).Cells(ActiveRows + 1, 2) + _
                Chr(&H22) + vbCrLf + "in " + Chr(&H22) + _
                Worksheets(Parts).Cells(ActiveRows + 1, 4) + _
                Chr(&H22), vbInformation Or vbOKOnly, _
                "Configuration Compleate"
        End If
        'Inform user the configurator has been saved
        MsgBox "The File " + Chr(&H22) + "L Conveyor Configurator.xls" + _
            Chr(&H22) + vbCrLf + "has been saved to reflect the changes made" + _
            vbCrLf + "by the configurator", vbOKOnly, "File Saved"
    Else
        'Inform user the configurator must be saved before exiting
            Chr(&H22) + vbCrLf + "has not been saved.  Please save this file before" + _
            vbCrLf + "closing to keep changes made by the configurator", _
            vbOKOnly Or vbExclamation, "File Unsaved"
    End If
End Sub
Sub Wait(Pause As Integer)
    Dim NewHour As Variant
    Dim NewMinute As Variant
    Dim NewSecond As Variant
    Dim WaitTime As Variant
    NewHour = Hour(Now())
    NewMinute = Minute(Now())
    NewSecond = Second(Now()) + Pause
    WaitTime = TimeSerial(NewHour, NewMinute, NewSecond)
    Application.Wait WaitTime
End Sub
Sub Auto_Open()
    'Show the TypeConFig Form
    TypeConfig.Show vbModeless
End Sub
Grant
SW2005 SP 3.1
P4 3.4 GHz, 2GB RAM
XP Pro SP2.0
