CURVE EQUATIONS
CURVE EQUATIONS
Know any sources on the web to find equations of curves (spirals, involutes, cam movements etc.) to be used to generate curves in parts?
RE: CURVE EQUATIONS
http://www
RE: CURVE EQUATIONS
Spirals can be created using a cylindrical coordinate system using the following format:
r = 5 + 2*t (5 is the base radius, 2 is the pitch times the # of turns)
theta = t * 3 * 360 (The number 3 represents the total number of full revolutions made by the spiral)
z = 0 (This just makes the spiral flat)
Cams can be created using a similar method.
Example: Simple sinusoidal cam profile
r = 10 + 3 * sin(t*360)
theta = t * 360
z=0
