control start-tp toolbars?
I recently downloaded a utility that helps to open ACAD dwgs we can't open in our office using ACAD 2002 called "DWGGATEWAY". When installed it added a toolbar set into the menu groups available throught the toolbars dailog box.
Every time I open a drawing, the toolbar appears on the screen, and I have to close it.
Is there a way to keep this from loading witheach drawing?
SD
RE: control start-tp toolbars?
the is a lisp file called acad****doc.lsp that supposedly is the place to add or remove items to load with each drawing.  The **** is the version, eg. running 2004, acad20004doc.lsp.
I havent tested this theroy though, be careful.
Alex
Dringo;
Thanks for your response. Using your info, I found a file related to the plug-in, and was able to change an argument in the lisp from "_show" to "_hide" (on a guess) and it worked!
sundemon
glad to hear it
happy cadding
Alex
