Color or numerical code for electrical wires into motor
4
6 wires going into a single phase, duel voltage motor
T-1, T-2, T-3, T-4, T-5, T-6
Is there a standad color code or number code as to where those wires go.
I want to be able to check the windings without opening up the case to see where the wires go.
Is there a place on the net where the code will be?
RE: Color or numerical code for electrical wires into motor
Does motor have nameplate information on it?
In most instances, the following information will help identify
a motor:
1. Frame designation
(actual frame size in which the motor is built).
2. Horsepower, speed, design and enclosure.
3. Voltage, frequency and number of phases of power supply.
4. Class of insulation and time rating.
5. Application
David Baird
mrbaird@hotmail.com
Sr Controls Designer
EET degree.
Journeyman Electrician.
Hello Frankie,
With this 6 leads the T1-T2-T3&T4 Leads Belogs to the Run Winding and the wires T5 and T6 to the Starting Winding, the first 4 wires can be connected in Serial (Join t2 & t3 and t1 and t4 for connect the High voltage)or  Shunt(Join t1&t3-Join t2&t4 and feed with Low Voltage  by each join).
Once you perform the run winding connections you have to connect the run winding with the satrt winding and then the motor will run.
You need The Six wires in order to connect this motor dual voltage.In this type of motor you don“t need color code, this only is finded in 1 Phase Multispeed Motors.
PETRONILA
frankiee
NEMA single phase motors Terminal markings identified by color are:
T1-Blue
T2-White
T3-Orange
T4-Yellow
T5-Black
T6- No color asigned (any other color).
