Analog through Serial Port
Hi:
I'm trying to monitor an analog signal through the serial port but I cannot figure out how to do it. Any suggestions or links would be appreciated. I'm using LabView 5.1.
RE: Analog through Serial Port
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
The Voltage range would be around 0 to 5V, bits of resolution - 16 bits, max sampling rate 500/s and I'm not sure what S/N ratio is. The DAQ would be alot easier.
we moved on to using a DAQ ... thanks for your help
