Newton Raphson Classical vs. N.R. Current Loop
HI All,
what is the difference between "Newton Raphson Classical" and "Newton Raphson Current Loop"?
The NR Current Loop method seems to solve much more easily, especially for my power sytem that has voltage problems in a particular area.  Actually the NR Classical won't converge, but the NR current loop does.
Is NR current loop as accurate NR classical, or does it use approximations that result in a less accurate solution?
RE: Newton Raphson Classical vs. N.R. Current Loop
What software is that with? Is there a defiition in their manual of the two methods.
It is digsilent.  Unfortunately there is no definition in their manuals.  I am going to write to them for a techincal note.  It is good software, but the manuals are not always helpful.
