integration in ansys
Hi to all
I wonder if there is a way to integrate a acceleration time history i ansys. I want to integrate my base motion input data.
regards.
regards.
RE: integration in ansys
CODE
fini
/cle
no_of_points=1234
*SET,XTIME
*SET,XFUNC
*SET,XINTE
*DIM,XTIME,,no_of_points
*DIM,XFUNC,,no_of_points
*DIM,XINTE,,no_of_points
*VREAD,XTIME(1),TIME_AXIS,dat,,1
(1f8.6) ! ##
*VREAD,XFUNC(1),FUNC_AXIS,dat,,1
(1f8.6) ! ##
C*** integrate
*VOPER,XINTE,XFUNC,INT1,XTIME
*cfopen,output,dat
*VLEN,no_of_points
*vwrite,XINTE(1)
(2f12.7) ! ###
*cfclos
Some points to note about this code. (1) Two files must be in the working directory TIME_AXIS.dat and FUNC_AXIS.dat, which contain the time base and the acceleration base, respectively. (2) You may need to modify the points marked ## to match the format of your input data (these are fortran format descriptors). (3) ### is the output descriptor. (4) The no_of_points parameter must match the number of rows in your input data. (5) change INT1 to INT2 to integrate your data twice and hence go from acceleration to displacement.
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
thanks
