Raw Water Iron Test?
I am interested in finding how to calculate a raw water iron sample on a machine that doesn't read higher than 3.30. I know how to cut the sample down and retest it to get under 3.30, but am I adding the readings together each time tested? Thanks.
RE: Raw Water Iron Test?
If you cut your sample to 1/3,(1 part sample, 2 parts distilled water) you triple your reading.
