step files to solidworks
i am using 2005 sp4 and i have some step sheetmetal files that i want to bring into solidworks and convert but its not working using fearureworks, anyone any ideas?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: step files to solidworks
However it will not matter if the Sheetmetal isn't one thickness or the bends are not true arc bends.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
You can try to import it.... then in the sheetmetal module you can use the Insert Bends tool, you must create a solid body, then use Insert Bends to convert the part to sheet metal.
Give it a try.....I've done it before and worked fine...
Colombo75
Industrial Designer
SW2005 SP4.0
The imported body must be one thickness for the Insert bends to work. The other thing about inserting bends on a imported body is that the Bends must be true arcs.
Hopefully that helps you understand my last statement above.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
