Forces on anti-roll bar link-rod ball joints
Can anybody tell me what sort of magnitude of forces are experienced by the ball joints at either end of an anti-roll bar link rod, as used on a typical European saloon car or small MPV?
Also, are any of these ball joints metal-to-metal or do they all have a plastic bearing cup?
Many thanks,
Zedrider
Many thanks,
Zedrider
RE: Forces on anti-roll bar link-rod ball joints
the force will be about 1000-5000 N max
Cheers
Greg Locock
I had expected the plastic cup to be standard, all the examples I've seen so far are like this.
I assume that link rods are only intended to take force aligned with the actual rod itself. (I suppose this would mean vertical forces only in most installations.)
What would you advise regarding application of force at right angle to both the longitudinal axis of the rod and to the longitudinal axis of either fixing pin?
I am currently persuaded this is a 'bad idea'(!), on the grounds that the connection of the rod to the retaining ring is a fairly weak weld.
I am looking for a suitable high angularity ball joint, with very low friction, for use in a hub-centre-steering motorcycle front hub. It will be subjected to braking and steering forces, but will not hve to take suspension loads, although it probably should be able to take jarring from road surface irregularities. The joint must also be very compact.
I thought I would ask the Auto suspension list since the MC engineering list still seems set on using telescopic front forks.
Thanks again,
Zedrider
You have been advised wisely that most ball joints have low force resistance in the axial, with respect to the fastened joint, direction.
I have been interested in a device similar to you, and I have seen one produced by the Dynalink division of Maclean Vehicle Systems. I believe it was for a European automobile. You can learn more about this company at:
http://www.mfmvs.com/
Cory
Best regards,
Matthew Ian Loew
Cheers
Greg Locock
Since this type of ball joint is not really suitable for my purposes, can anyone recommend a source of high articularity, metal-to-metal ball joints that can take radial and axial forces and have compact dimensions?
ZR
Cheers
Greg Locock
I don't want to use a joint with a plastic cup because the joint needs to have no preload (otherwise it will interfere with steering input and feedback) and a plastic cup cannot safely be modified to remove preload. (An established UK design of hub-centre-steering used the lower ball joint from an Austin Mini. The preload is removed by compressing the joint axially in a bench vice.)
For the first prototype I want to avoid machining a new hub and hope to use an existing drum-brake type motorcycle hub with the brakes shoes removed. The ball joint would be fitted in the anular space vacated by the brake shoes, somewhere below the axle line, in whichever orientation is most suitable for the application.
I hope this makes the situation a bit clearer.
ZR
