Replacing some old 5Cr Valves with 2-1/4Cr
We are replacing some old 5Cr Gate Valves. Operations has requested Ball Valves since they are easier to operate. The only ball valve I can find that meets all of our requirements is only availabe in 2-1/4Cr. The 2-1/4Cr material (A217-WC9) has higher allowable stresses than 5Cr (A217-C5) at the same temperatures so I think it should be fine.
Does any one know if there are any issues with putting the 2-1/4Cr valve into the existing 5Cr piping?
The connections are flanged so welding is not an issue.
RE: Replacing some old 5Cr Valves with 2-1/4Cr
The 2¼-Cr steel in some cases will not be a good choice. One of which is alluded to by metengr. Another case would be sulfidation corrosion.
~NiM
