How to change color off parts affect by assembly change
I have an assembly with 2 subassemblies. Each of these subs contains about 10 to 15 parts. The first sub is fixed while the second is position behind it. I can take the second sub assy and move it further back as long as I edit the connecting parts lengths in the first sub to accommodate for the difference. Is there any way that when I move the second sub assy I can right a rule, check, action, etc. at the major assy level that will highlight, or notify me of the affected parts in the subs?
Thanks for any help
Thanks for any help
RE: How to change color off parts affect by assembly change
To see how to do this active that option and experiment on a two part assembly.
