first angle an third angle projection
hello,
i was wandering now that i am working on my config.pro skills,
i am pretty tired of changing the option third angle to first angle (seen i'm belgian)
now putting this option in my config.pro doesnt seem to help i tried config mentor from 3d logix he gives me : "projection_type first_angle" but the config checker from plaf cortens site gives back an error , unknown feature...
so according to his site i guess it should be "19_PROJ_ANGLE" an hidden option.
this doesn't work either, so my question is: is it because i open the default template (this should be the case)? or is there an other option to activate? if it is the template where can i find those?
thank in advance
tonton sam
lovin to config but every start is hard
ps: is there some published work somebody could recommend me? a book or some sort of pdf :)
thank in advance
tonton sam
RE: first angle an third angle projection
You can create a template drawing and place the template views.
Template views will fail only if the views overlap each other when the drawing is created. If you are trying to replicate views on drawings that aren't created yet, this is the way to go.
Create or open your template drawing. It can't have a model associated to it when you are done.
In drawing mode;Select Applications > Template to enter template mode. Now place your views.
If you need more help, Search the Knowledge Database for drawing templates. There are lots of how-to documents
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
This is a personal preferences kind of thing, if you are making a lot of changes in your config.pro file. I found this out the hard way
You can't make edits when you open it up... it defaults to last file read... the way around it is..on showing.. pick that and choose current session.. now you can change anything.. and save all.. to a new file name.. copy and paste if it works the way you want.
In your master copy of config.pro sort it out by function
and use remarks... precede lines with a !.. using notepad to edit and having configpro_mentor.. it makes live a lot easier down the road... again personal preferences
Ben Loosli
Ingersoll-Rand
i was doing that already, i like it nice an neat so when i give it to somebody else the can see everything easely,
let me paste it here, sorry if it's too long, :) and if there are remarks, please go ahead, i just started so it's kinda small at this time
hmm no i'm gonna upload it : http://ipo.wepsaait.be/2ipo/proE/config.pro
greetz
tonton sam
tho;
beheer toestanden
makes me think of the last roadside soberity test I had
i hope you made them worth while when they stopped you ;)
i always tend to make jokes, and after 10 min they pretty much let me go :) (when i'm sober of corse)
