pile Groups under Lateral Loads, by FHWA
Does anyone know where I can obtain a copy of "Behavior of Piles and Pile Groups under Lateral Loads ", by FHWA?
Jili
Jili
RE: pile Groups under Lateral Loads, by FHWA
i think i remember seeing that document or one that had a similar name.
Good luck
FM
http://2
Depending on your exact need, perhaps you could consider using an alternate source - the US Army "Design of Deep Foundations". Parts of Chapter 4 (Piling Lateral Loads) are taken, with permission, for Dr. Reese's work. Here it's link
http:/
www.SlideRuleEra.net
This publication is available for order from NTIS. I ordered a copy recently myself. The total charge came to about $90 US for a paper copy. Electronic versions of this are, I believe, unavailable, even from NTIS.
If you do want to order a copy, you will need to cite the NTIS publication number (PB86-238466) either by email or telephone to the NTIS order department. As the publication is pre-1990, it is not in their database of publications and not orderable using their online system.
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
SlideRuleEra
Is there something wrong with the way they have scaned the document? The "equal " sign and some other caracters dont show up properly.
FM
When I produce a .pdf file from a scanned document, the scanner creates a .tif file (an exact pixel by pixel image of what the scanner sees). Then, print the .tif document (using freeware) as .pdf file. The freeware fools your computer into "thinking" that it is sending the .tif file to a "real" printer. In reality it creates the Adobe .pdf file that you can store on the hard drive.
The quality of the print-to-.pdf conversion of this Army document is very good.
Hope this helps
we use acrobat 7 in the office , same problem
