RSEMULATE 5000
RSEMULATE 5000
RSEMULATE 5000
I have a small problem in that when the rack is configured in RSEMULATE 5000 it shows two rslink programs running.
One is RSlinx itself and the other seems to be RSlink Enterprise.
My question is this, is it possible to turn off or disable RSLink Enterprise, as this also interferes with the DF1 driver in RSLINX.
Such that you have to delete the DF1 driver from RsEnterprize before you can add a DF1 driver in Rslinz.
RE: RSEMULATE 5000
I have Rslinx and Rslinx Enterprise running as well when I use the emulator.
I also use Rsview which uses Rslinx Enterprise and I cannot delete either module.
Are you using the DF1 driver to communicate with a Panelview while you are running the Emulator?
RE: RSEMULATE 5000
Try Slot->Remove Module.
RE: RSEMULATE 5000
Thanks for the replys,
I have tried deleting the Df1 driver in in Rsview with no joy.
I have also tried Slot remove module and this has no joy.
Anymore suggestions.
jonesy29847 do you have the same problem or not??
RE: RSEMULATE 5000
Yes, but not a roblem as RSView uses RSLinx Enterprise so I can test HMI functionality too.
