Check Location Straight Lengths
Please advise any texts, websites that addres the question as to how close a tilt check valve should be located to the pump, discharge bends, instruments,
I seem to recall that some vendors recommended 6D pipe lengths between any fittings and a check valve to avoid the flow pattern disturbing the flapper.
RE: Check Location Straight Lengths
as you will know a nozzle type check valve like Noreva can be installed directly on pump discharges, behind ellbows, etc.
