calculation of heat loss from a hot water ppr80 pipe
hi all
how can i calculate the heat loss from a polyproplane pipe conveyed hot water to radiators ? the eqn. of the overall heat transfer is
1/u= (1/hiAi)+ (1/hoAo)+ thick./k
which thick.=0.3 mm , ho= h air at 23c  ,
 hi= h water at 75c   k= thermal conductivity of ppr80 pipe
i want these values
i dont know if i should add the radiation loss or not??
RE: calculation of heat loss from a hot water ppr80 pipe
Radiation tends to be less significant at lower temperatures so you could exclude it. For h to air you need the value using natural convection. It's about 10 W/m^2 C but you'd be better looking at the full formula. For heat loss to the fluid there are simplified equations in MacAdams Heat Transfer book. Alternatively use the Engineer's toolbox http://www.engineerstoolbox.com/
corus
