how to install content center library?
Hi, I've autodesk inventor series v.10.  3 CD's, I choose the complete installation option.  I insert the first Cd, then the second, then the third one.  When I insert the third one it asks me to insert the aforementioned content center library.  It says it's a CD.
Is there a fouth autodesk inventor CD, or should I do something specific to install it?
Thanks.
RE: how to install content center library?
if you ordered the cd's then yes it did come with 4 cd
I thought there were five?  Vault?
Contact your dealer or Autodesk.
I had this problem with the trial version.  Apparently there is a bad batch out there.  Supposedly my serial number (or batch number) did not match the bad ones, but I still had the problem.  Only solution was get the dealer to send new disks (he sent a five disk set that worked).
