Grease or oil??
Grease or oil??
Grease or oil??
have a Weinman pump made in Columbus Ohio.
It is 1 1/2 HP 230V, Mdl 5ACK158.. It has a grease nipple on one end of motor case and a screw at the top on the other end of motor case in line with the grease nipple. How often should I grease it? And do I oil the screw end or take the screw out and put a nipple in and grease that end too?
Why would one end be greased and not the other if that is the case??
