Steel coupling
Steel coupling
We are inserting valve on 16" CI Sewer FM and proposing Style 62 Dresser coupling (CI to DI transition coupling) on each die of ex. FM.
My question is if pipe line is buried then can I use Dresser Style 62 (Steel MJ adaptor) coupling. Would it be vulnurable to corrosion? Do I need to specify any treatment/wrapping for Steel Coupling
Any suggestions?
Any suggestions?
RE: Steel coupling
RE: Steel coupling
We are proposing MH on valve but since line is too deep don't want to include MJs within MH (from cost point of view)
My question is...will Steel Coupler will do okay if it is buried from corrosion point of view
