safe programme error messages
Hello
I am having a error message while using SAFE. This is Runtime error 5. Invalid procedure to call or argument. Any body has a clue what is this and where i can get information about these error messages. Any suggestion is highly appreciated.
RE: safe programme error messages
I don't know the language used to write SAFE, but in Visual Basic, Invalid procedure call or argument (Error 5) is:
Some part of the call can't be completed. This error has the following causes and solutions:
·    An argument probably exceeds the range of permitted values. For example, the Sin function can only accept values within a certain range. Positive arguments less than 2,147,483,648 are accepted, while 2,147,483,648 generates this error.
Check the ranges permitted for arguments.
·    This error can also occur if an attempt is made to call a procedure that isn't valid on the current platform. For example, some procedures may only be valid for Microsoft Windows, or for the Macintosh, and so on.
Check platform-specific information about the procedure.
Thank you very much for feedback. Actually I am not aware of the programming of this software. I think lot of structural engineers use this software for design of reinforced concrete slab. May be some body can specifically address this issue for SAFE.
I really appreciate all of those whocan give some idea about this.
Thank you vey much.
Email or call CSI technical support.
Dear rfb1234:
I have used SAFE many times but haven't encountered any such difficulty.  I think there may be some error in modeling. Check your model thoroughly and I believe it will work.
RSMEngr
