Wood Truss Bracing
Wood Truss Bracing
Does "ANSI/TPI 1-1995" aka "National Design Standard for Metal Plate Connected Wood Truss Construction" really exist?
If it does, I sure would like to know how I could get a copy. The ANSI web page isn't any help. TPI doesn't seem to have a web page, and Wood Truss dot com will sell you a commentary on ANSI/TPI 1-1995, but not the actual standard. I'm particularly interested in permanent lateral bracing design.
Thanks!
Thanks!
RE: Wood Truss Bracing
and more importantly there exists current commentary and
ballot for the 2002 stanadard which probably should be
followed / revised more enthusiastically.
wtca.com
Good Luck!
Man, talk about finding a needle in a haystack!
Now it says "copyright 2001" but I tell you, I sure couldn't find any links to this site or anything else until your reply. Nevertheless, it's nice that TPI is one the web.
