Underground tank buoyancy?
I am designing an underground concrete stormwater tank. It is rectangular and has extensions at the bottom to prevent uplift. Ground water is at surface level.
What is the buoyancy force on such a tank? I can calculate the force due to the water, but what about uplift due to soil pressure?
Also, what wedge angle should I assume resists uplift? Some say the soil friction angle, and others say no more than 10 degrees.
Tom
Tom
RE: Underground tank buoyancy?
